help swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2007, 11:45 AM   #1 (permalink)
View leppercon_man's Photo Gallery
help swap
hey i need some help. i got my hands on a supra engine for my 1984 celica and i need to know what i'm gonna need to make her work. apparently it should just bolt in so i don't have to make any brackets or anything but as for anything else, i'm pretty lost
leppercon_man is offline   Reply With Quote
Old 05-23-2007, 12:44 AM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
I wouldn't put that Supra engine (5M-GE ?) into a Celica.
The Supra has a longer front chassis to make room for the longer engine.
The same engine in the Celica is going to touch the radiator.
And the weight of the engine will be too far forward over the front axles, which will give very bad handling.
If you're still determined, you have 2 choices.
1.
Relocate the gearbox backwards and possibly make a recess in the firewall so that the front of the engine sits in a reasonable place.
Not sure if the sump will clear the crossmember.
This will give nice handling but will take a lot of custom fabrication.
2.
Rrelocate the radiator in front of the radiator support panel, put an electric fan in front of the radiator and live with crap handling every time you go around a corner.
- Stepho
stepho is offline   Reply With Quote
Old 05-26-2007, 09:16 PM   #3 (permalink)
BANNED
View w203's Photo Gallery
You have the two engines in front of you (unless you don't have the Supra engine). Look at the mount placements and you should have your answer.
w203 is offline   Reply With Quote
3sgte swap into a 2.2 NA MR2 pdxvento MR2 Forum 12 03-28-2007 11:59 PM
2zz-ge swap info igorien2k MR2 Forum 4 03-25-2006 01:37 PM
20V Swap, can someone help? -HiTMaN- Archived Corolla threads 8 02-24-2006 05:02 PM
4agze w/auto swap ? SuperV Archived Corolla threads 0 02-13-2004 01:29 PM
4A-GZE Swap - More Details? clumzy Archived Corolla threads 8 08-31-2002 12:02 PM
