Engine swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2007, 05:45 PM   #1 (permalink)
RJR
View RJR's Photo Gallery
Canada Engine swap
Can a 1984 celica 22re be bolted up to the transmission of a 1986 22re toyota pickup SR5 4 BY 4 ?
Do you need to use the celica computer or can you use the truck computer? Is there any advantge of using on over the other?
Both car and truck are 5 Spd standards
RJR is offline   Reply With Quote
Old 05-30-2007, 11:24 PM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
Yes.
All 22R engines have the same bellhousing bolt pattern.
Not sure about the computer.
Are you putting the Celica engine into the pickup or the pickup trans into the Celica?
- Stepho
stepho is offline   Reply With Quote
Old 05-31-2007, 02:08 AM   #3 (permalink)
DCM
One with the farce
Gameroom cash: $106800
View DCM's Photo Gallery
Yes, it will bolt up.
No, ECM's (and block/head are different). The early 22R-E (not the same as the 22-RE in your truck) doesn't use a knock sensor or electronic timing advance.
To make it work you will have to drill and tap a hole in the block for the knock sensor that's on the truck engine.
Swap ALL your truck parts over; intake, exhaust, distributor, accesories, brackets, wires, etc. onto the Celica engine, as well as the oil pan and oil pick-up tube.
'92 ST185 All trac turbo
'92 AE95 wagon x2
'72 TE27
DCM is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
Harsh 2-1 Downshift while in 'S' Mode Mistabullet 5th & 6th Generation (2002-2006 & 2007-2011) 20 03-19-2007 08:01 AM
Engine swap (3vzfe) by Ben-RR & me mox Camry & Solara Lounge 18 11-28-2006 12:43 AM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
