Override park gear? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2007, 04:47 PM   #1 (permalink)
View Valgar's Photo Gallery
Override park gear?
Hello I have a '93 Celica ST Coupe.
I went out to start my car, it was totaly dead. I hadn't driven it in about ~6 days or so, but I havn't had any problems so no clue why it would completely die. The car is parked in the garage so i need to push it out so I can Jump it.
I turned the key to the on position but cannot get the car out of park.
I read somewhere about older toyotas having a problem where teh break light stays on and locking the car in park. So maybe the brake light went on and drained the battery? any info would be helpful here. I couldnt locate the bright light switch that people were talking about on my car.
I also checked the fuses, i heard they could be a problem, they are fine..
if anyone know please fill me in ASAP
thanks!
Valgar is offline   Reply With Quote
Old 06-03-2007, 03:17 PM   #2 (permalink)
Occupation : Foole
View PhantomS's Photo Gallery
First off, I can't comment on as to why it won't start. Am assuming, from the sound of your post, that you have an automatic tranny, as do I in my '92 GT 'vert. To "override" the tranny lock, there is a small button slightly to the right of the shifter and slightly fwd of it when in P position, labeled "shift lock override" (at least on mine - dunno if the ST is different, due to the different engine...dunno), but anyways.... depress/hold down that button and shift car from Park to Neutral - then, turn key to "unlock" steering lock, and push the car outta the garage. Hopefully the ST tranny is the same, as it's quite easy and plain on the GT. Hope this helps, and good luck on getting it started.
PhantomS is offline   Reply With Quote
Old 06-03-2007, 03:35 PM   #3 (permalink)
Heh, no my tranny has no override shift button... which is strange, since my GF's camry has one and I know most auto trannies do have them. But I havn't be able to locate one for this car anywhere.
I really need help with this, anyone!??
Old 06-04-2007, 02:22 PM   #4 (permalink)
View toyomoho's Photo Gallery
The car may not have a visible labeled button. Look around the shift console panel above where the P, D, R, etc letters are. See if there is a small tab that can be easily pried out. Underneath would be a plastic tab, when pressed with something like a screwdriver will allow the shifter column to move.
Old 06-04-2007, 03:50 PM   #5 (permalink)
goldi5sfe's Avatar
View goldi5sfe's Photo Gallery
you should have one wtf
1989 Camry_sold
1996 Camry_daily driver
2001 Accord V6 Coupe_still modding
goldi5sfe is offline   Reply With Quote
Old 06-13-2007, 11:54 AM   #6 (permalink)
View tankd0g's Photo Gallery
As for the battery drain, check your dome light. The switches on the doors are a real crappy design and when they fail they fail in the on position.
tankd0g is offline   Reply With Quote
Old 06-13-2007, 01:19 PM   #7 (permalink)
View wiccanferret's Photo Gallery
That's good info. My '94 Corolla has something like that...I always thought it was just a tease...maybe where they would've put the override button had they put one. Who knew there was something under it?
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 06-13-2007, 03:50 PM   #8 (permalink)
Occupation : Foole
OK ... YEAH !!! Have heard of that as well (was forgotten...) Likely that'll solve the problem .... my wife's corolla has the same "hidden" override, didn't know Toyota used it way back when, for goodness sakes
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
4th Gear RideMr2 MR2 Forum 9 07-19-2006 05:20 PM
Ring Gear ROBS Camry & Solara Lounge 17 05-07-2006 10:40 PM
Idle drops/engine bogs in gear (auto) tsuave Celica Forum 2 04-17-2006 02:53 PM
Rolla XRS gear box TCPOWER Archived Corolla threads 16 02-18-2006 04:18 PM
