need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2007, 10:20 PM   #1 (permalink)
View 93 celica GT's Photo Gallery
need help
I have a 1993 Toyota celica the problem i am having is the car runs and idles fine for a while but then stalls out... Before its about to stall it will idle at 2,000RPM just wanted to see if anyone could help... I brauoght it to a Specialist and they said they could not find the problem.... I baught a new map sensor put that in and it did shit.... I also decided to buy a new ECU didnt put that in yet wanted to know if i should do that. Thanks to people who can help me out much appreciated!
93 celica GT is offline   Reply With Quote
Old 06-06-2007, 12:22 PM   #2 (permalink)
Gameroom cash: $147537
Clean the throttle body and every hole in it. Remove battery -ve before you start to reset ECU.
If it still fail, get another ICV. The green thing at the bottom of the throttle body.
Old 06-22-2007, 05:44 PM   #3 (permalink)
I replaced that part and it did not fix the problem was wondering if u had any other ideas please tell me i'll do anything to get this running right! thanks
Old 06-23-2007, 01:42 PM   #4 (permalink)
View toyomoho's Photo Gallery
The ECU is expensive and may not solve the problem. You have replaced the two most logical parts MAP and IAC valve. Rather then guess, read up on this engine. The Camry uses the same engine the manual link is below. Or take it to a Toyota dealer for a diagnostic.
http://oregonstate.edu/~tongt/camry
Old 07-17-2007, 08:30 PM   #5 (permalink)
Well Just wanted to say thanks for the help i found out the problem. I had to get a new EGR valve mine was clogged. I also had to get a new engine coolant temp sensor so if u know anyone who is having the same problem let them know what i had to do... Thanks again!
