85 Celica Check engine Code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2007, 12:27 PM   #1 (permalink)
View dewd's Photo Gallery
Hi Folks, I could use some help.
I pulled the codes by jumpering the check engine connector on my 85 Celica, 22RE.
I got 6 flashes of the check engine light followed by 12 flashes.
The 6 and 12 flashes continuously cycle, first 6 and then 12 then it repeats.
Can you tell me how to interpret these flashes or where I can get the info to interpret them.
Thanks a million.
dewd is offline   Reply With Quote
Old 06-18-2007, 12:51 PM   #2 (permalink)
View CELICAGTS24's Photo Gallery
European Union
According to my toyota manuals these codes that you are describing are straight count codes for older model toyota's.
The 6-Digit codes indicates: rpm signal or circuit, no rpm, TDC signal.]
But as for code 12 i cannot find anything yet.
CELICAGTS24 is offline   Reply With Quote
Old 06-18-2007, 04:31 PM   #3 (permalink)
View tonyconvert85's Photo Gallery
The 12 code i believe is the knock sensor. This is pricy if bought new and if cable is damaged, then you need to find where the cable is broken.
Tony
tonyconvert85 is offline   Reply With Quote
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
Check engine code P0511???? RREMPLE Yaris, Vitz and Echo Forum 1 10-26-2006 12:55 PM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
Weird Code from Check Engine light.... (Searched...) Pookie1986 Camry & Solara Lounge 3 05-27-2005 11:35 AM
