My daughter has a 95 Celica ST 1.8 manual transmission.
It has been leaking gear oil from the axle seals for a few weeks.
I have not had a chance to replace them, so it has kept leaking (my bad).
Just the other day she tells me that when driving on the highway, it will pop out of 5th gear into neutral. She said it would stay in 5th if you hold the stick.
I drove the car last night and it happened to me. I drove the rest of the way home in 4th at 3,500 rpm.
Finally the question...could it being low on gear oil be the cause of the problem?
Could the gear get over heated and pop loose?
Is there something else that is causing this problem?
I am going to drain the oil and replace the seals tonight.
Any help is appreciated.
