Brake Change 00' GTS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2007, 10:59 PM   #1 (permalink)
View SHYHEIM103's Photo Gallery
I'm about to change the brakes and rotors on a 2000 GTS and was wondering if there were any special tools needed, or anything i should be looking out for. i know in order to change the rotors on my impala i have to change the bearings as well. is this the case for the celica too? TIA
SHYHEIM103 is offline   Reply With Quote
Old 06-19-2007, 06:33 PM   #2 (permalink)
View toyomoho's Photo Gallery
Not up on this model. On most late model Toyota’s the pads can be removed once the caliper is unbolted from the torque plate. The torque plate needs to be removed only if the rotor is being changed. The rotor usually easily slides off, held in place by the hubs studs and brake pads. If the car has ABS, take care not to damage the sensor which is usually held in place by one bolt.
Old 06-19-2007, 09:32 PM   #3 (permalink)
ok thanks Toyo! i'll probably get around to doing this tomorrow then. Although i think my fiance wants ceramic brakes now, instead of the el cheapo Autozone lifetime warranty brakes because of the dust. Thanks again!
07 V6 brakes? lalojamesliz 5th & 6th Generation (2002-2006 & 2007-2011) 31 06-18-2007 08:56 AM
DIY somewhere for a 92 Celica GT Conv. brake pad change? JPS911 Celica Forum 2 05-01-2007 10:35 PM
Change brake pads of 2002 Corolla dougone Archived Corolla threads 2 09-17-2004 01:36 AM
When to change brake fluid? Ken4 Camry & Solara Lounge 2 09-10-2002 08:20 PM
