78 celica Clutch trouble
Hello ok on my 78 Celica i cant not get it to shift into any gear while its running i bled the clutch hydraulic line with no luck
goes in gear when off but not when running i even treid to start in gear but it acts like clutch is engaged with pedal down it went through a flood here couple years ago it sat in bout 4 ft of running flood water for several hours water went down and away that night
i went out and started it day or two later but did not drive it anywhere i am thinking now the clutch /pressure plate /flywheel may be rusted together clutch has only six months drive time on it so i know its good what else could be causing this
any help greatly appreciated
Thanx
Larry
