Ignition problem of Celica 1985
The timing of my Celica 1985 is always about 30 degrees when engine is at idle. I used timing light to adjust it to 5 degrees, but the engine will stall when I shift the lever. When I adjust timing to 10 degrees, my car can run, but engine loses power and burns too much gas( around 15 miles per galon).
If I don't adjust timing( 30 degrees), the idle is very rough, and it burns about 19miles per galon.
This car was over heat and somebody fixed it before itis mine.
Please give me some advice or main reasons.
thank you very much.
