Tdc
Hey...just because the crank pully/harmonic balancer is pointing to zero degrees...doesn't mean it's at Top dead center.
You have to find tdc of the first cylinder... and to do this, you must figure out which cylinder is about to fire.
Look in your service manual, and locate the #1 cylinder. Remove the spark plug for this cylinder. (this next step you might have to do a couple times until you find the right spot...) crank the pully around until it hits Zero. At this point, take a screw driver, very very very gently stick it in the spark plug hole. If your screw driver instantly hits the piston inside, then you're at TDC for the #1 cylinder. (if you want to tune it further for mor accuracy, then read up on how to use a degree wheel)
Now, one issue you might have (depending on if you had to remove your distributor during the change or not...i'm not sure on your engine)... is that before you remove the distributor, you're supposed to mark exactly where your distributor is pointing when the engine is at TDC. During re-assembly, you'll have to feed the gear at the end of the distributor back into place and make sure the dist is pointing to the spot it was prior to removal.
If you didn't mark this spot prior to removal, then you should read up on installing a new distributor (you don't actually have to install a "new" one...but that will tell you how to possition the distributor correctly.). Also...to get the dist close, look at the distributor cap...and follow the #1 spark plug cable to the point where it enters the cap. The distributor should be pointing to this wire when the engine is at TDC.
hope this helps!
~Shogun
