89 Running Bad - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2007, 09:08 PM   #1 (permalink)
View cajunbull61's Photo Gallery
89 Running Bad
My son's 89 started missing bad today. It idled rough and missed and sputtered when you give it gas, especially a lot of gas. It would miss and sputter until it gained some rpms then run better. I put a set of plugs in and it ran better but still sputtered. Ran it for a while and the idle got worse. Drove it and it sounds and feels like its only running on 3 cylinders at times. It will idle smooth then pop several times out the exhaust then smooth then pop a few times again. I didn't have the tools to check the cap and rotor but that will be next. Any other suggestions on what to check???? It's an 89 GT with about 170000 miles on it.
cajunbull61 is offline   Reply With Quote
Old 07-30-2007, 10:50 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
plug wires and cap
Old 07-31-2007, 11:00 PM   #3 (permalink)
Ok, I ran some seafoam thru it, helped but no dice. Replaced the cap and wires and was worse? I noticed the air intake hose was torn near the manifold. I taped it up and changed out the clamp and it runs better than before the problem started. Thanks for the advice.
Old 07-31-2007, 11:11 PM   #4 (permalink)
frankie g.'s Avatar
View frankie g.'s Photo Gallery
you should check all the basics like oil . headers. all the wiring. and the alternater
frankie g. is offline   Reply With Quote
89 pick up won't stay running boonies 89-95 Toyota Pickup/Hilux 7 06-14-2007 04:29 PM
camry v-6 running bad Uluacam 3rd & 4th Generation (1992–1996 & 1997–2001) 3 09-26-2006 03:22 PM
89 sr5 corolla needs help, bad mpg, hesitates CodyjCA Archived Corolla threads 3 05-03-2004 01:42 AM
Alternator bad? 89 Camry shuluke 1st & 2nd Generation (1983–1986 & 1987-1991) 6 09-11-2003 11:00 PM
89 V6 running rough chris-k 1st & 2nd Generation (1983–1986 & 1987-1991) 1 06-27-2003 08:32 AM
