Starting issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-04-2007, 06:31 PM   #1 (permalink)
View 92-gt's Photo Gallery
Question Starting issues
ok, so i am in quite a quandry, my car has no spark whatsoever. the story goes like this. i was driving home from work one day and i stopped to get gas, when i came out from paying my car wouldnt start. after about 15 minutes it finally started, the next day it did the same thing, after it started i went to carquest but left it run this time as i went inside, when i came out it had shut off. it started again after about 15 minutes and i got it home, as i was pulling in my garage it died again. i started off by replacing the coil, then it wouldnt start, no spark, then i asked one of the techs. where i work and he suggested the ignitor, i replaced this and still no spark, then i replaced the whole distributor(assembly and cap and rotor) and still nothing. at this point i was quite angry because i had spent over $300 and i still had no spark, i decided that it may be the ecu, (the person that had it before me had a security system, remote start, and remote locks, and they hacked into the ignition harness, and a few other harnesses, i repaired all the wires and wiring but i thought that somehow this may have shorted out/fried my ecu) and i still have no spark....the fuses and relays are all good, i have power to my coil and ignitor and ecu....i need help and i need it fast, let me know what you think.
my car is a 1992 toyota celica gt 5sp. with a 5sfe engine.
thank you,
ryan
92-gt is offline   Reply With Quote
Old 08-04-2007, 06:58 PM   #2 (permalink)
View toyomoho's Photo Gallery
Have you checked to see if the coil and ignitor are receiving DC power? Go to the link below and download the Gen 3 Camry ignition section. The two cars have the same engine, might help.
http://oregonstate.edu/~tongt/camry
Old 08-04-2007, 11:18 PM   #3 (permalink)
nevermind, i got it started, i followed the wire harness back to where it feeds through the firewall and one of the power wires that splits and feeds to the ignitor and disty. was a little messed up, and then i messed with a few connectors and it fired up ...figures it was just a simple problem AFTER replacing $700 wirth of parts ...but there is one thing, it feels like its missing a little bit when i get on it...the plug wires are all pluggued in right, the plugs are brand new, any ideas?
91 corolla starting issues tysn Archived Corolla threads 2 10-24-2006 09:14 PM
'97 starting issues Hoobee RAV4 Forum 0 10-09-2006 09:22 PM
94 4-cyl starting issues TKde0 3rd & 4th Generation (1992–1996 & 1997–2001) 1 09-15-2006 02:27 PM
Starting issues w/93' pickup- 22RE Yota_master 89-95 Toyota Pickup/Hilux 6 09-10-2006 06:24 PM
starting issues moner8888 Hardcore Tech and Competition 2 06-28-2004 02:15 AM
