play in steering wheel? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2007, 04:34 PM   #1 (permalink)
View turnandburnae86's Photo Gallery
working with a 1984 celica gts (22RE)
I have about 6 inches of play in my steering wheel befor the wheels actually start to turn. is there some sort of adjustment for this somewhere?
is that normal for these cars? even if it is i dont like it!
turnandburnae86 is offline   Reply With Quote
Old 08-07-2007, 05:28 PM   #2 (permalink)
View toyomoho's Photo Gallery
This is way too much play. Suggest you jack up the front end of the car, remove the tires and investigate. Look at the steering rack ends, tie rods, etc to see if they are moving when the wheel is turning.
There is no adjustment for this, sounds like worn or loose parts.
Old 08-08-2007, 02:12 AM   #3 (permalink)
DCM
One with the farce
Gameroom cash: $106800
View DCM's Photo Gallery
yeah, X2! The steering on those cars should be nice and tight, good handling car when everything is as it should be.
Also check the steering box - the steering shaft and the pitman arm should move at the same time. If they don't, the steering box can be adjusted by tightening the slotted screw on the top, as per the service manual.
'92 ST185 All trac turbo
'92 AE95 wagon x2
'72 TE27
DCM is offline   Reply With Quote
Steering Wheel Noise Trd_Thunder 2nd Generation (2005+) 9 02-21-2007 12:05 PM
Dealer told me my steering wheel is supposed to be crooked! da5176 1st Generation (2001–2007) 8 06-13-2006 09:38 PM
repair steering wheel - wear on spokes celicaGTswan85 General Discussion 4 04-07-2006 04:45 PM
steering wheel play 73ch13 Camry & Solara Lounge 5 12-13-2004 08:21 PM
