Thanks for the advice. I ordered the dealer bearings today from 1sttoyotaparts.com. Even with 2nd day shipping they were cheaper than the local dealer.
I did some more work. The problem is, now today I honed 2 Cylinders and pulled a main bearing cap. The honing I did with a flex hone, but there are some pitting and areas where it looked like something corrosive "dripped" down the walls on the front side only. My guess was it came from water leaking from the BHG. Should I keep honing it? I took some pretty decent pictures and on Flickr. You can click on "all sizes" and see the higher res versions. The second problem is the main bearing cap I removed. The wear is not nearly as bad as the rod bearings, but the journal I am worried about. It feels smooth in the rotational direction, but I can catch a fingernail on ever so slight lines going across the journal (right to left)
Here are the pictures:
http://www.flickr.com/photos/9237872@N05/tags/7afe/ I can take more if unclear. I did hone some more and they did turn out better.
I am at a crossroads - Do I replace the rod bearings, reassemble the pistons with new rings and and just hope the mains hold out? The plans are to keep the car for a few years for my daughter in college (locally). Or do I bite the bullet and do the only things left, which I think are:
Pull the Block, Remove crank
Regrind Crank, oversize bearings
Bore the Cylinders and get new Pistons/Rings (No idea on new pistons cost)
At that point, New Oil Pump, New Water pump
I just don't have the multiple rebuild experience to know what it should look like. I think I am leaning toward just replacing the rod bearings, rings and putting it back together.
Thanks for any insight to steer me in the right direction.
