would a 5m-ge fit into an 85 celica gts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2007, 07:23 AM   #1 (permalink)
View steevieg's Photo Gallery
thanks for replies
steevieg is offline   Reply With Quote
Old 08-20-2007, 08:28 PM   #2 (permalink)
DCM
One with the farce
Gameroom cash: $106800
View DCM's Photo Gallery
There are a few threads on this topic already, and the general concensus is that it's cheaper and better to buy a Celica that already has the I-6 in it. That way, instead of going from a 22RE to the bottom of the line 6-cylinder, you can (more easily) bolt in the 7M-GE, 7M-GTE, or the any of the J-series engines.
'92 ST185 All trac turbo
'92 AE95 wagon x2
'72 TE27
DCM is offline   Reply With Quote
Old 08-21-2007, 01:28 AM   #3 (permalink)
do you think you could link me to a couple of those threads? i searched and didn't get any good results =T
Old 08-21-2007, 02:36 AM   #4 (permalink)
DCM
One with the farce
http://www.toyotanation.com/forum/t201705.html
http://www.toyotanation.com/forum/t201968.html
http://www.toyotanation.com/forum/t194196.html
By Stepho, October 2006
The 7M-GTE will fit any of the early Supras but the Celica has a shorter engine bay.
People have made it fit but you have to deal with a very tight installation and a lot of weight very far forward (ie bad handling).
The radiator would have to be moved to the frotn side of the radiator support panel (even more weight going forward).
Either that or relocate the firewall back a few inches (expensive).
And the rear end will need upgrading to Supra spec to cope with the turbo's grunt.
Better to get a 2400cc 22R block and put a 20R head on.
Most bits (crossmember, gearbox, etc) remain stock.
Add a cam, decent exhaust and 150HP isn't hard to reach - pretty good in a light body that still handles well and can drive everyday.
Won't be anywhere near the sheer grunt of the 7M-GTE but at least it will go around corners instead of ploughing into the trees.
There are lots more, just type in "engine swap" in the Celica forum and sift through for what applies. Hope this helps.
'92 AE95 wagon x2
'72 TE27
noobie runnin a 91 Celica GTS 5thgenGTS Introduce Yourself Here 3 12-13-2007 11:53 PM
FS: 86 Toyota Celica GTS Toy-King Vehicles 12 11-12-2007 10:49 AM
Feeler: '85 Celica GTS TubRog5 Vehicles 4 05-23-2006 12:09 AM
85 Celica GTS Fuel Pressure Problem Denis Celica Forum 6 03-16-2006 08:11 PM
FS: Toyota Celica GTS, Toronto, Ontario, CANADA celica1211 Vehicles 0 03-10-2006 01:16 AM
