Wilwood Proportioning Valve
Hello all,
I was hoping to replace the proportioning valve (p-valve) in my 90 Celica GT while replacing a cracked brake line, only to find out that it costs $300! It's in pretty rough shape, rust wise, and I suspect I will end up destroying it when I go to disconnect the cracked brake line from the p-valve.
After some research, I found the Wilwood #260-8419 adjustable p-valve which I read is usually used in tuning applications. This option would be significantly cheaper, because I can buy these on eBay, but I'm unsure of quality of this solution. Just wondering if anyone can give me some insight on installing such a p-valve instead of the factory one. Thanks
