Help! Carrier Bearings Celica GTS??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2007, 05:28 PM   #1 (permalink)
View robertmach's Photo Gallery
Question Help! Carrier Bearings Celica GTS???
Toyota dealer says I need to replace carrier bearings in Transmission on 2000 Celica GTS, 6 Speed MT.
Can I do this without pulling transmission?
Thanks
robertmach is offline   Reply With Quote
Old 09-09-2007, 09:28 PM   #2 (permalink)
joeyicu's Avatar
View joeyicu's Photo Gallery
no, if your asking this question, no offense, take that sucker back to the dealer and spend the few thousand dollars for them to yank that FWD manaul out and fix them suckers
what is the car doing anyways?
-<2001 Chevrolet 2500HD 6.6L 5A 4x4>- 14.6@88mph - Edge Juice Chip, Cut Muffler
-<1990 Nissan 300zx NA 5M 2+0>-
Stillen Catback, Kenwood HU
joeyicu is offline   Reply With Quote
Old 09-10-2007, 07:40 AM   #3 (permalink)
Celica carrier bearings.
Car has load bearing roar. Deal mechanic put on lift, used stethoscope to locate noise. Are the bearings in a transaxle which can be reached without going through the complete transmission? Any info on dropping tranny?
Thanks
Old 09-15-2007, 07:38 PM   #4 (permalink)
joeyicu's Avatar
you might not have to tear down the whole transaxle assembly, you mightbe able to just remove the transmission, split the case, and then replace the carrier bearings on the differential then slap it all back together...
the job pays a hair under 10 hours, i think you may be biting off more then you can chew brother in law...but theres what youd be working with once you have the trans out
Old 09-17-2007, 12:20 PM   #5 (permalink)
Thanks for info
Thanks for info. Going to pull, take to tranny shop.
Robert
noobie runnin a 91 Celica GTS 5thgenGTS Introduce Yourself Here 3 12-13-2007 11:53 PM
1984 celica gts drive shaft HELP!!! turnandburnae86 Celica Forum 1 07-08-2007 11:03 PM
1991 Celica GTS questions? TeRcElIcA Celica Forum 5 03-13-2005 09:23 PM
92 Celica GTS Plat Celica Forum 7 06-21-2004 09:07 PM
