Motor keeps coming out of timing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2007, 09:12 PM   #1 (permalink)
View Curmudgeon5462's Photo Gallery
Alright, I've got a puzzling issue with my 92 celca ST.
When I bought the car it had trouble in low rpms, and just ran bad altogether. It kept on getting worse to, gradually until I couldn't make it up my driveway without it dying. I fixed this by moving the distributer all the way counterclockwise, and it ran perfectly for a while, then started getting worse and worse again. I cant figure it out, the timing belt isn't slipping or anything.
Anybody ran into this before? HELP!!!
Curmudgeon5462 is offline   Reply With Quote
Old 09-12-2007, 10:41 AM   #2 (permalink)
Gameroom cash: $147537
Don't think its timing. Check your idle. Probably need to adjust the idle screw.
Old 09-12-2007, 11:31 AM   #3 (permalink)
No, if it were the idle I would only have trouble at take off, and it wouldn't shake out that quick. My gas milege was cut in half as well, and an off idle screw wouldn't do that.
Any other ideas?
Old 09-12-2007, 11:59 AM   #4 (permalink)
Box driving
View Boxedin's Photo Gallery
It sounds to me like you may have a faulty Mass Air Flow meter. Adjusting the timing via distributor may allow the engine to run properly for a short time with the air fuel settings the way they are. I would look up the specs on the amount of ohms the MAF should be at and test it with a multimeter. If thats not it try investigating the throttle position sensor. I really doubt the engine is slipping time like that... Under normal circumstances the engine will slip time one or two teeth once and then not again for a while. Or it will slip a great amount all at once leaving you with an engine that normally will not run at all. Let me know if I can be of anymore help.
08' Scion Xb 5 Speed -39K miles-
(2az-fe)
88' Toyota Celica All-Trac Turbo 5 Speed -97K miles-
(on blocks, car cover on, STABIL in the fuel tank, in storage)
07' Honda Fit 5 spd auto. 237k miles. (yeah believe it)
Boxedin is offline   Reply With Quote
Old 09-12-2007, 12:25 PM   #5 (permalink)
^92 ST use 1.6L 4A-FE which is MAP base.
It is not a timing problem check everything else. Did you check timing with timing gun? Check ignition components. Pull ECU error code.
Old 09-12-2007, 03:30 PM   #6 (permalink)
Box driving
Good call, I accidently disregarded the "ST" Which brings me to the fact there could be an issue with the MAP sensor seeing how it does a similar job in a different way. This is an OBD 1 vehicle so there may be no codes. Checking ignition components is a good idea.
(2az-fe)
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
timing belt! CamryBrotha 3rd & 4th Generation (1992–1996 & 1997–2001) 11 05-01-2007 05:38 PM
Newbie Q's: Timing Belt,Brake Fluid, Repair Manual DeafBug Camry & Solara Lounge 8 05-05-2004 10:11 PM
