You have to keep in mind that the most heat is generated right after you stop and turn off the car. Mostly because there is no air circulation to help cool things down. This type of heat soak can last for quite a while after the car is turned off. It applies to everything from your brakes, engine, transmission, exhaust and so on. Im betting he never had the brake fluid flushed either, which makes things worse since it absorbs moisture over time. Once the fluid completely cools down the brakes will feel normal again.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
