Originally Posted by eabostick
Thanks it's good to know that it will be all right for a while. Is this something that can be fixed at home or will I need special equipment? Thanks again for any and all help.
If you go to the auto parts store, you can find sockets specifically for oxygen sensors. They are easy to replace. Just make sure you let the exhaust cool down before you work on it. Spray the sensors with some PB blaster, liquid wrench or equivalent to get them loosened up. Sometimes they are hard to get out.
You will also need to pull the carpet back on the passenger side floorpan to access the wiring where the o2 sensors plug in. The harnesses plug in by the fuse panel that would be by your left leg if you were sitting in the passenger seat.
Good Luck!
