tranny questions.
i own a 1990 toyota celica gt coupe, it has the 5sfe mottor autotranny with overdrive. now my question is can i swap the transmission with a 1988 toyota camry 5speed. and if i can. can that 5 speed handle boost from a ct26 turbo? if it can what ecu should i use? and what kind of map censor should i use, would the ideal map censor be the 2bar of the mr2 turbo or would i need a different map censor? i have to do alot of patch work on the floor boards so any trimwork would need to be done anyways so if i could use the 5 speed it would be the ideal time to do it. any input that can be given in this cituation would be great. thanks
