Bought an All-Trac...What to do? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2007, 08:59 AM   #1 (permalink)
View Sleeping Turbo's Photo Gallery
I just bought an all trac what is the first mod to do?...I was originally just going to swap in a 3sgte into a non all trac, but i looked at all the money to fix up the engine i had, i just decided to buy an all trac
Sleeping Turbo is offline   Reply With Quote
Old 09-16-2007, 01:00 PM   #2 (permalink)
View TubRog5's Photo Gallery
Tune up and oil change is always the first mod.
TubRog5 is offline   Reply With Quote
Old 09-16-2007, 01:16 PM   #3 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
Do all the basic maintenance first, before any performance mods. That'll be expensive enough and keep you busy for awhile. What year is your All-Trac?
Rick89GTS is offline   Reply With Quote
Old 09-17-2007, 01:36 PM   #4 (permalink)
it's a black on black 90 with 5spd manual
Old 09-17-2007, 07:08 PM   #5 (permalink)
Nice buy. I've got a '90 Celica GT-S with a swapped 3sgte. Sadly, I'm not quite amused with it has I thought I'd be. I'd be more satisfied with an alltrac.
Old 09-18-2007, 12:53 PM   #6 (permalink)
Box driving
View Boxedin's Photo Gallery
I agree with the rest here, tune up, oil change, any needed maintenance, to ensure it will last. Once you are done with all of these things my first mod to any turbo car is to install a downpipe. Nothing extravagant, just something to help her breathe and erk another pound or so out of the turbo, spool time will also be greatly reduced. Overall, one of the greatest all around modifications you can do, it will not hurt drivibility and not put any undue stress on the internals. Let me know if I can be of any more help.
08' Scion Xb 5 Speed -39K miles-
(2az-fe)
88' Toyota Celica All-Trac Turbo 5 Speed -97K miles-
(on blocks, car cover on, STABIL in the fuel tank, in storage)
07' Honda Fit 5 spd auto. 237k miles. (yeah believe it)
Boxedin is offline   Reply With Quote
Old 09-18-2007, 05:51 PM   #7 (permalink)
Thanks alot, i definetly due a straight tune up and general maintenance, but after that i'll defiently install a new down pipe.
Old 09-18-2007, 06:09 PM   #8 (permalink)
A blow off valve is one of the things on the priority list after general maintenance. T-bolt clamps are a good upgrade from the stock ones.
Old 09-18-2007, 07:50 PM   #9 (permalink)
View A Diddy's Photo Gallery
downpipe, front mount intercooler with blow off valve on piping and a manual boost controller will keep you happy for a while. I would also recommend headers at the same time as the downpipe. Blitz has a badass set for 500 bucks
2004 G35 6MT
1991 3sgte Celica GTS
A Diddy is offline   Reply With Quote
Old 09-19-2007, 08:16 PM   #10 (permalink)
Thanks all this stuff is gonn help alot. I also plan to fit a new Blitz Nur Spec R exhaust with FMIC and the BOV. Is there anything else like in the area of braking and suspension?
Old 09-20-2007, 02:35 PM   #11 (permalink)
Box driving
If you are going to use this car as a daily driver I wouldnt change anything in the suspension. At the most maybe some stabilizer bars. In the area of braking you should be good but maybe a light upgrade to some ceramic pads if not already equiped. Mind you, ceramics in some cases are a little louder but do not tend to cause as much brake fade under severe stops.
(2az-fe)
Old 09-20-2007, 07:00 PM   #12 (permalink)
a modest 1.5 inch drop will make the car look alot more agressive, alot of people have dropped daily drivers.
2004 G35 6MT
Old 09-21-2007, 01:35 PM   #13 (permalink)
thanks i was thinking about that anyways
Old 09-24-2007, 05:42 PM   #14 (permalink)
View klone1000's Photo Gallery
Hay guys its been a long time. Since the 5sfte have cracked all 4 pistons, i have buy a 2nd gen 3sgte to go into my 1992 toyota celica gt. My question is does the 3sgte clutch work with the 5sfe transmission? In the rush to get the engine in i just bolted the 5sfe transmission on to the 3sgte using the 3sgte clutch and the 3sgte pressure plate. I then got worried so before i continue i want to make sure i done it correctly.....
klone1000 is offline   Reply With Quote
Old 09-30-2007, 12:23 PM   #15 (permalink)
View AWDios's Photo Gallery
If I had it all to do again, I would have started with suspension mods, and then moved to power. I would start with a boost gauge and a recirculated BOV as well as a turbo timer so your stuff will last longer. Then a boost controller up to like 12psi. You'll be able to run safely with that much boost, and this will give you the most power gains for the money ($75 for a decent MBC). Then looks at some stuff to lower your intake temps as that wngine bay gets nice and warm, straight intake FMIC, or WTA IC. Then I would do a down pipe and exhaust. But that's just me.
WWW.PSTOC.ORG
Puget Sound Toyota Owners Club President
Sales and Leasing Consultant and Scion Champion - Toyota of Kirkland
http://www.facebook.com/rogercarrTOK
AWDios is offline   Reply With Quote
1997 alvalon's trac off stays on lv6l 1st Generation (1995-1999) 8 03-23-2007 01:25 AM
Check engine light and TRAC OFF light, anyone able to help? rwhisner 3rd Generation (2005-2012) 4 11-23-2006 03:57 PM
1988 Camry All Trac 5speed bj3sgte Vehicles 2 12-27-2004 12:40 AM
Corolla all trac questions TheProfessional Archived Corolla threads 7 07-27-2004 03:01 PM
just bought a 91 Tercel help a noob 91BEATERTERCEL Tercel, Paseo, Starlet, and Sera Forum 7 06-30-2004 12:27 PM
