big problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2007, 08:28 PM   #1 (permalink)
View leppercon_man's Photo Gallery
Canada big problem
k i was driving my 84 celica and all was good but suddenly the engine cut out and the rpm's dropped down below 1 and this would happen for a minute or 2 then she'll work properly again. then i turned her off that evening and the next morning she wouldn't start it just idels low then stalls. first i thought it was something with the fuel filter like it being really clogged or whatever but it's still pretty good. fuel pump is still working and i'm at a loss dunno what else it could be
leppercon_man is offline   Reply With Quote
Old 10-14-2007, 11:23 PM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
I had similar problems when the EGR valve died on my 18R-G.
Effectively it created a big hole in the inlet manifold and the fuel mixture just leaned out.
- Stepho
stepho is offline   Reply With Quote
Old 10-15-2007, 12:05 PM   #3 (permalink)
Canada
so how'd u fix it
Old 10-15-2007, 06:28 PM   #4 (permalink)
View digmycelica's Photo Gallery
I would guess that the coil has very weak spark or the ignition module is failing.
Pull the coil wire out of the dist. cap and hold it about 1 1/4 inch from the dist.cap hole and see if the spark jumps that far when a helper is turning the car over. if not, move it closer . If you have to hold it within 1/4 inch before the spark jumps, then I would replace the coil.
digmycelica is offline   Reply With Quote
Old 10-16-2007, 10:20 PM   #5 (permalink)
and how do i know if its the moduale that's failing and not the coil
Old 10-16-2007, 10:39 PM   #6 (permalink)
usually a module or igniter assy. will just go all the way out all at once. I think some of the parts stores like Auto Zone or Advance Auto used to have a way to test them but not sure if they still do that or not. If you have weak spark, I would change the coil, if no spark it could be coil, igniter, or pick-up coil in distributor. hard to tell sometimes without test parts available.
Old 10-29-2007, 09:55 PM   #7 (permalink)
k so i completely replaced that coil, plus i popped a new started in cuz she wasn't turning over and she worked fine for about 5 minutes then it idled between 200 and 300 then it stalled and hasn't started yet. i been thinking i should replace the spark plug wires next but any other suggestions would be quite welcome
Big Problem! Please Help! nuchieboy 3rd & 4th Generation (1992–1996 & 1997–2001) 7 10-10-2006 07:23 AM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
odd vibration problem niju321 Camry & Solara Lounge 3 07-07-2005 12:15 PM
Motor Mount problem and other, please help lazycat Camry & Solara Lounge 4 08-16-2004 09:32 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
