Torquing head - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2007, 12:06 PM   #1 (permalink)
View lleroyb's Photo Gallery
Torquing head
Anyone know how I should torque the head bolts on an '89 Celica with the 4afe 1.6 engine? I have read about three different ways. I went by the Chilton's manual which said to torque them in three steps to 47ft/lbs (I think). Others say to torque to a lower value then another 90deg in three steps. Yet another source said torque to a value then two 90deg turns.
What is the correct method?
Thanks,
Lou
lleroyb is offline   Reply With Quote
Old 10-22-2007, 01:03 PM   #2 (permalink)
Gameroom cash: $147537
From 1990 Celica Toyota Manual:
Old 10-22-2007, 01:11 PM   #3 (permalink)
Thanks,
Thanks so much. I will double check the value I used. At least I know we weren't supposed to do the "clocking method".
Lou
Old 10-22-2007, 01:47 PM   #4 (permalink)
Yea, I need to do the 90deg thing on my 5S-FE. Its a bitch to do.
Old 10-24-2007, 08:53 PM   #5 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $156340
View 4agetercel's Photo Gallery
Mostly all Toyotas do have the 90degree angle torque my Tercel had to have the 90degrees as well so get used to it if youre thinkin about taking the head off of something, 90degrees is a piece of cake...just use a johson bar ...try 180dgrees on a VW thats a bitch
4agetercel is offline   Reply With Quote
Old 10-24-2007, 08:58 PM   #6 (permalink)
Wonderbread
4agetercel's Avatar
Yeah most Toyota engines have an angle torque spec so get used to it my Tercel has the same thing 22ft/lbs 34ft/lbs and then the 90degrees its a piece of cake comepared to the 180degrees for a VW... anyways as far as torque specs always call a Toyota dealer they should be able to help you out and i find theyre the best, i dont trust the aftermarket manuels
head gasket and head bolts Molokai68 89-95 Toyota Pickup/Hilux 6 06-05-2007 08:47 PM
Blown head gasket sealer? Retraction wheredoesthisgo Archived Corolla threads 1 05-08-2007 10:08 PM
Corolla/Prism Head Gasket wheredoesthisgo Archived Corolla threads 3 03-24-2007 11:39 AM
