gts engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2007, 12:50 AM   #1 (permalink)
View hm86gts's Photo Gallery
gts engine
hello all
new to this site
but i've owned couple of celicas already the past 7 years
recently own an 86gts coupe
the engine started leaking oil
hi mileage
need recomendation on engine swap or rebuild shops
or just buy rebuild parts
i have rebuilt a 2.4 chrysler motor before simpler design i think compared to the toyotas and less electronics to hook up just looking at it
so just would like opinion on the best and cheapest route
i just want the car to run reliably
no performance stuff
it's pretty quick stock for a 20year old car
thanx
hm86gts is offline   Reply With Quote
Old 10-26-2007, 01:12 PM   #2 (permalink)
View 90gtsindenver's Photo Gallery
After looking around myself, I can tell you.....the rebuild option isn't cheap, unless you do it yourself. The replacement option is there, but you'll likely end up with a 3sfe (I think 2.0 motor) I tried risingsunmotors and some others, a "bolt in replacement" runs about 1k. (plus shipping) and they'll quote you the 2.0 instead of the 2.2 so keep that in mind.
I've gotten quotes for rebuilds anywhere from 2k and up. (if you have the money, its not THAT bad) If you can do it yourself, you can usually slide in under the 1k mark, depending on how much machining you need. I know the autoparts stores around here sell the "kit" for 600 bucks, although I'm not sure what all that includes. If you have the time and space, and the knowhow, I'd go for the "do it yourself" option personally.
You can find engines online though, if you want to just replace it. Sounds like you have some clue how to do the job yourself, which should help cut down on costs though. Good luck, and keep us posted.
90gtsindenver is offline   Reply With Quote
Old 10-27-2007, 05:07 PM   #3 (permalink)
View miguassiel's Photo Gallery
The fastes and cheaper way to do that is just bying an used engine. I have past through that a few times already.
miguassiel is offline   Reply With Quote
Questions about Toyota engine families Sulu General Discussion 3 10-09-2007 06:08 PM
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 10:38 AM
Harsh 2-1 Downshift while in 'S' Mode Mistabullet 5th & 6th Generation (2002-2006 & 2007-2011) 20 03-19-2007 09:01 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 01:05 AM
1989 GTS Engine Montanahelp Celica Forum 6 07-03-2005 03:55 AM
