My A/C is underwater! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2007, 04:32 PM   #1 (permalink)
Bike Zen's Avatar
View Bike Zen's Photo Gallery
Well, not really, but it sounds like I have water bubbling in the dash! (even when the AC is off) My first thought was the drain tube was blocked. So I hooked a shop vac to it fired up the AC and it seemed to have flow. A little water came out, but only a few drops.
At the same time it smells really musty. I think I can get some fungicide for the intake to fix this, but I have a feeling the problem is bigger than that.
Any A/C pro's out there???
Thanks in advance
D
Bike Zen is offline   Reply With Quote
Old 10-26-2007, 04:54 PM   #2 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
The water bubbling in the dash sound is typically air trapped in the heater core. Bleeding out the coolant sytem should take care of that. The musty smell is probably the AC.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 10-26-2007, 05:01 PM   #3 (permalink)
Bike Zen's Avatar
Silly Question
I guess I just assumed the smell and the sound were related.
Now.....
How would one go about bleeding the coolant system??
(if the explanation is too long,just say so & I will look it up)
Thanks for the tip!
D
(EDIT: I found a "how to" for bleeding the coolant system on line, but any tips would be appreciated)
Old 10-26-2007, 05:23 PM   #4 (permalink)
Gameroom cash: $147537
Or engine overheating. Check coolant level and fill it up. With engine running, turn control from hot to cold fast a few times. With proper coolant level, the system will breed air out in a few days. Do the hot to cold a few time to speed it up.
Old 10-26-2007, 05:33 PM   #5 (permalink)
Bike Zen's Avatar
That sounds simple!
The engine temp is fine, just the bubbling sound from the dash. The method I read about involved suspending the reservoir, releasing the bleed valve, adding fluid while running, etc. You method sounds easy
Scarborough Ontario? Hows the weather? No wild fires i bet! (I lived in Hamilton for a year)
Thanks Again,
D
92 Celica ST - After 1 year of not driving A/C does not work Guitarlp Celica Forum 5 07-05-2007 04:46 PM
A/C always on; bad dash switch? bad relay? How to Test? ladd2 Camry & Solara Lounge 8 05-01-2007 07:11 PM
1998 Avalon A/C Issues ignoreme 1st Generation (1995-1999) 2 04-11-2007 11:47 AM
A/C Not blowing Cold Air garrand3006 Archived Corolla threads 4 08-09-2006 05:08 PM
