It doesn't sound like either the battery or the starter because it sounds like the engine is cranking, if the engine isn't cranking then yes it would probably be one of those 2 things. There are a few basic problems that you need to look at that it could be. It could be that its not getting spark, fuel, or air(or to much air). Check your air hose for cracks or splits this can cause the engine to run lean, and check the filter it would have to be really clogged up to hinder starting, these are about the least likely for it to be. Check your spark plugs and make sure they are sparking, if they aren't then there can be several reasons. Spark plugs could be bad, bad wires, bad distributer, or even just a bad connection. Make sure all your connections are good on the spark plugs and distributor. The last thing I have for you is to check to make sure that you are getting fuel pressure, if your not then its probably your fuel pump. Without more info I can't really tell you much more.
Make: Toyota
Model: 1991 Celica GT
Engine: 5S-FE
Trany: 5 Speed Manual
Miles: 154k
