The 8R-C and 18R-c share many parts except for the pistons (not sure about rods and crank).
You can do a direct swap to any 18R engine with no drama.
You can also swap to any 20R (2200cc), 21R (2000cc) or 22R (2400cc) with little drama apart from getting the correct sump (front or rear bulge most clear your crossmember).
By the time the 22R engine came out Toyota had changed from you steel case manual gearbox to an alloy case.
It bolts straight up to the engine and accepts the same drive shaft but the gearbox crossmember will need to be modified (needs extra arms welded on because it bolts to the chassis in a different place).
Most Toyota gearboxes had multiple versions with the gearstick further forwards or backwards.
Measure and compare before you buy.
I made a small typo on the first reply.
The 1900 Corona is an RT83, not an RT80 (which was 1500cc).
Here are some specs on it.
http://members.iinet.net/~stepho/cor...htm#corona83pr
The RT72 Corona Mark II hardtop is a good reliable car.
They last forever and are easy to work on when they eventual break.
Getting quite rare now so it could be quite a head turner if done with a clean and simple paint job.
It has the same engine and gearbox as the RT83 Corona and accepts the same upgrades.
http://members.iinet.net/~stepho/cre...htm#markII72pr
Both cars are very similar to the early Celicas and shared many parts.
So the following Celica FAQ will cover many topics on your cars (especially for the engine).
http://members.iinet.net/~stepho/celfaq.txt
If you have reasonable mechanical skills then my recommendation is to drop in a 22R (carb) or 22R-E (EFI) with a mild cam and add a complete aftermarket exhaust system (including aftermarket exhaust manifold).
If you're more skilled or more daring then go for the Lexus 1UZ-FE.
Keep one car driving on the road and the other car in the workshop.
At suitable times (every 6 months?) swap them over.
Eventually both cars will be show stoppers.
My own mistake was to attempt to modify my '77 Celica while driving it to work.
Too many jobs were rushed (Monday morning looms) and I'm having to redo most of it.
- Stepho
