Actually your code is for the air intake temp sensor. Check to make sure the you've got a good connection. Also look at your intake hose running from air filter box to intake. Make sure there aren't any splits it your hose(Not sure if this could still set off that code but thought it would be a good thing to look at just in case) if there are any splits you can just duct tape it until you can fix it. If non of the above help then get yourself a new air temp sensor and hopefully that works for ya. Good Luck!
Make: Toyota
Model: 1991 Celica GT
Engine: 5S-FE
Trany: 5 Speed Manual
Miles: 154k
