91 Gt - No Power!? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2007, 09:07 AM   #1 (permalink)
View Kaziganthi's Photo Gallery
Angry 91 Gt - No Power!?
I have a 91 GT, 5SFE with no power under load, alreday cleaned the cat, changed fuel filter and plugs, took out the air filter, wires are next... the coil was jerried off of who knows what... the coil wire itself was broken but has been re-engineered. when I unplug it from the cap there isa fine white dust and some obvious charring... Could this be what is causing my SEVEER lack of power(I can spit farther faster)????
Kaziganthi is offline   Reply With Quote
Old 11-28-2007, 12:05 PM   #2 (permalink)
Celica Enthusiast
bbmx952's Avatar
View bbmx952's Photo Gallery
Does it rev good at all? Or does it only rev up so far? Have you checked to make sure or spark plug wires are connected good on plugs and distributor cap? Have you checked the distributor? NEED MORE INFO!!! lol
Make: Toyota
Model: 1991 Celica GT
Engine: 5S-FE
Trany: 5 Speed Manual
Miles: 154k
bbmx952 is offline   Reply With Quote
Old 12-01-2007, 02:11 PM   #3 (permalink)
Can you kill a toyota?
View 91celicagt-s's Photo Gallery
same problem here, revs fine (maybe a little slow) but tops out at 6000 not 6500. had this problem for 80k miles. So it can't affect drivablity
94 Toyota 4X4
91 Toyota Celica GT-S
98 Chevrolet Camaro Z-28
91celicagt-s is offline   Reply With Quote
Old 12-01-2007, 02:21 PM   #4 (permalink)
Changed the plugs and wires all together, it will rev in park no prob, and even move slugishly when cold, but when she gets warm, the rpm will flutter between50 and 950 and the thing won't get out of it's own way. After running for a while and I shut it off, it won't start and kick a really sick rich exhaust stink back thru the vents...
Old 12-01-2007, 10:35 PM   #5 (permalink)
Celica Enthusiast
bbmx952's Avatar
Maybe check your timing.... Im kinda at a loss on this one.
Make: Toyota
Engine: 5S-FE
Miles: 154k
Old 12-04-2007, 12:22 PM   #6 (permalink)
Celica Enthusiast
bbmx952's Avatar
I was thinking today, maybe your valves are gunked up. If your able to I would check that out.
Make: Toyota
Engine: 5S-FE
Miles: 154k
Old 12-05-2007, 02:29 PM   #7 (permalink)
i think if the timing were out, the behavior is too inconsistent, and no error codes on the dash lights... seems to defy logic
Old 12-08-2007, 12:50 PM   #8 (permalink)
Heard mention of the temp ctrl sensor that will not code on the dash, gonna try that... as soon as I find it
Just a little info I'd like to pass along.. Mr Marv Audio, Video, and Security - Tech 17 01-22-2008 07:49 PM
91 celica GT part out 3SGTE@daSpeedof Car Parts for Sale 11 01-20-2008 06:39 PM
'91 GT leaking masive amounts of P/S fluid?? shortlid Celica Forum 11 04-04-2007 10:51 AM
about 91 celica gt lights jbtonno Celica Forum 0 07-10-2006 05:46 PM
85 Gt Coupe And 91 Gt Hatch Deeon Show & Share 3 05-24-2006 08:52 PM
