replace headlights? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2007, 10:13 PM   #1 (permalink)
View mongjong's Photo Gallery
replace headlights?
hey im looking to replace my stock headlights with some hid blue/white ones.. does anyone know if i can jus buy the bulb and relpace it..or do i need to buymore?
mongjong is offline   Reply With Quote
Old 11-30-2007, 12:04 AM   #2 (permalink)
The Puddle Jump 2!
View sheep's Photo Gallery
what year is the car?
sheep is offline   Reply With Quote
Old 12-02-2007, 05:22 PM   #3 (permalink)
hey.. its a 95 model.. thanks
Old 12-02-2007, 09:52 PM   #4 (permalink)
View 00mysticteal's Photo Gallery
Being that it is a 95, you should be able to remove the bulb from the headlight assy correct? Well if that is the case then you can put the hids in the car and not have to buy new headlights. The hid kits work as a plug and play set up. You install a box usually secure it along the inner fender, then plug your stock plug into this box and run the new wires/plug coming from the box to the new bulb they give you and then you have hids. Hope this helps you. Just post up if you have more questions. Just search hid kits under google and trust me it brings up alot of options and info.
00mysticteal is offline   Reply With Quote
Old 12-11-2007, 09:04 PM   #5 (permalink)
if i just wanna replace the bulbs to the brighter blue/white ones..rather than replacnig everything..is that ok to do? or does it burn too hot? .. sorry noob here
Old 12-11-2007, 11:31 PM   #6 (permalink)
View Mondo131's Photo Gallery
HID conversions are as easy as just replacing bulbs.
Rather then just a bulb that is a little brighter than stock, you get a bulb set up that is truely HID(High Intesity Discharge)
As mysticteal said, HID conversions are as easy as pluging your stock wiring into the control box, then running the wires from the box to the headlight assembly.
Spend the extra cash and get the simple HID conversion, you wont regret it.
Mondo131 is offline   Reply With Quote
Real HID's not necessarily "better" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 26 12-11-2006 06:06 PM
need to replace my headlights... flyboi 3rd & 4th Generation (1992–1996 & 1997–2001) 13 12-06-2006 12:53 AM
Headlights assembly replacement IgorTacoma 1st Generation (1995.5–2004) 4 09-26-2006 01:29 AM
jdm headlights problem rjthebattousai Solara 1 08-25-2006 10:49 AM
replace headlights toyota corolla 99 toyotapad Archived Corolla threads 2 11-13-2004 05:33 PM
