Your not going to get anyone except the dealer to program a new remote for you, but you can fiddle with how your stock alarm works.
Passive Arming On/Off Selection, Entry Delay Time Selection
The RS3200 is factory-set to not Passively Arm. to change the system's operation for Passive Arming operation, as well as adjust the Entry Delay time, follow the procedure below. (Start procedure sitting in driver's seat.)
1. Before you begin:
Close all the doors, and the trunk or hatch.
Unlock all the doors with the inside lock switch.
Remove the key from the ignition switch.
2. Start the Programming Procedure. (Complete all steps within 30 seconds)
a. Using the remote control, lock, then unlock, the doors 3 times.
b. Open the driver's door.
c. Lock, then unlock the driver's door handle lock button 3 times.
d. The system lock the door in 2 seconds; if this does not happen, start over.
e. Unlock the driver's door handle lock button.
3. Select the Operating Mode & Complete the Programming Procedure.
a. Close, then Open the door:
2 times = Passive Arming OFF
3 times = Passive Arming ON,
0 sec Entry Delay
4 times = Passive Arming ON,
15 sec Entry Delay
5 times = Passive Arming ON,
30 sec Entry Delay
b. Lock then unlock the driver's door handle lock button 1 time.
c. The system locks the door in 2 seconds; if this does not happen, start over.
d. If the system successfully locks the door, programming is now complete.
RS300 Door Lock Selection
The RS3200 is factory-set to unlock the driver's door when the UNLOCK button is pressed on the remote control, the unlock the remaining doors when the UNLOCK button is pressed again within 3 seconds. You may change the programming so all doors will unlock at once with the UNLOCK button is pressed by following the steps below. (Start the procedure in the driver's seat.)
2. Start the Programming Procedure. (Complete all steps within 40 seconds)
a. Insert the key into, and remove it from the ignition switch 2 times.
b. Close, then open the driver's door 2 times.
c. Insert the key into, and remove it from the ignition switch 1 time.
d. Close, then open the driver's door 2 times.
e. Insert the key into the ignition and leave it in.
f. Close the driver's door.
g. Turn the key from LOCK to ON 4 times (ending at LOCK).
h. Remove the key from the ignition switch.
i. The tail and marker lights flash 4 times and the buzzer chirps 4 times.
j. The doors will lock and unlock 1 time. If this does not happen, start over.
3. Select the Operating Mode and Complete the Operating Procedure.
a. Press and release both LOCK & UNLOCK on the remote at the same time.
b. Press and release the UNLOCK button once for all doors unlock.
or
b. Press and release the LOCK button once for driver's door unlock.
c. The tail and marker lights flash 1 time and the buzzer chirps 1 time.
d. The doors will lock and unlock 1 time. (If it locks twice, start over.)
e. Open the driver's door; programming is now complete.
RS300 Ignition Controlled Auto Lock
The RS3200 is factory-set to automatically lock you vehicle's doors when you turn the ignition key to "ON" or "START", and unlock the doors when you turn the key back to "ACC" or "LOCK". To change the programming of this feature, follow the procedure below. (Start the procedure in the driver's seat.)
a. Insert the key into the ignition switch and turn it from LOCK to ON 5
times (ending at ON).
b. The tail and marker lights flash once, and the buzzer chirps once. If this
c. The Status Monitor's LED (or the engine immobilizer LED turns on for 30
seconds.
a. Close the door = IG. Controlled Door Locks ON
or
a. Close then open and close the door again = IG controlled Door Locks OFF
b. Turn the ignition key back to LOCK.
c. The tail and marker lights flash once, and the buzzer chirps once if the
system was set for IG door lock control ON, twice for IG door lock control
OFF. If this does not happen, start over. Programming is now complete.
