Rod Bearings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2007, 02:18 PM   #1 (permalink)
Celica Enthusiast
bbmx952's Avatar
View bbmx952's Photo Gallery
Rod Bearings
Ok. So the I have a bad rod bearing in my celica. Its going to cost me $775 to drop a rebuilt engine in after the core refund. I don't exactly have the money to get the rebuilt engine, and don't really think that I am able to rebuild the engine myself. So my question is and I'm afraid I know the answer but, can I replace the rod bearings without doing a whole overhaul on the engine?
Make: Toyota
Model: 1991 Celica GT
Engine: 5S-FE
Trany: 5 Speed Manual
Miles: 154k
bbmx952 is offline   Reply With Quote
Old 12-04-2007, 03:01 PM   #2 (permalink)
6G Celi Specialist
Supersprynt's Avatar
View Supersprynt's Photo Gallery
Mmm no. You're going to have to rip the motor apart to begin with so your automatically going to replace the headgasket, water pump and timing belt while its out on top of pulling the pistons apart.
Your cheapest and easiest solution would be to find a used 5SFE from someone who has recently swapped and put that in.
Check celicatech, 6gc.net, & mr2oc for used motors. I'm sure someone is selling one.
Supersprynt is offline   Reply With Quote
Old 12-04-2007, 03:16 PM   #3 (permalink)
Celica Enthusiast
bbmx952's Avatar
I dont know about the headgasket but i know i shouldn't have to replace the water pump and timing belt. All 3 of those are new... my water pump had gone out on me about 2 months ago and the engine overheated which caused a valve seal to jam the valve open. So I just had the head off then and had replaced that all then.
Make: Toyota
Engine: 5S-FE
Miles: 154k
Old 12-04-2007, 03:27 PM   #4 (permalink)
Celica Enthusiast
bbmx952's Avatar
Well let me ask this, what are the repercussions of just climbing under the car, taking the oil pan off, and replacing the bearings. Tell me what would happen?
Make: Toyota
Engine: 5S-FE
Miles: 154k
Old 12-04-2007, 04:10 PM   #5 (permalink)
View toyomoho's Photo Gallery
The issue is the rod bearing journal on the crank could have been hammered by the bearing and is now bad. If so, a new bearing will not last very long.
If this engine has counterbalance shafts you will need to remove these before getting to the crank.
Old 12-04-2007, 04:29 PM   #6 (permalink)
6G Celi Specialist
Theres a harmonic balancer, pretty sure it's the same thing.
If you replaced all that stuff then your OK.
IMO you should really have it looked at by a professional, in case there is internal damage.
Old 12-05-2007, 03:58 PM   #7 (permalink)
Celica Enthusiast
bbmx952's Avatar
Grr.... Figured as much, I just really don't want to bite this bullet.
Make: Toyota
Engine: 5S-FE
Miles: 154k
98 camry 4cyl how to buy rod bearings dsparkaz Introduce Yourself Here 0 07-22-2006 07:13 PM
1zz-fe Warning!!! Rod Bearings and Lubrication 2001rolla Hardcore Tech and Competition 12 07-14-2006 02:19 PM
3SGTE rod bearings tamalpro MR2 Forum 3 03-24-2006 12:09 PM
Rod Bearings and Window....>.< importdriver007 Camry & Solara Lounge 0 11-28-2005 09:40 PM
