Help with Celica not Running
I have an '01 Celica I'm having problems with.
Heres what its been doing before today:
When I get gas, whatever amount, it runs extremely ruff for a few minutes. Once I get going it settles down and runs fine. That is the only time it has given me any trouble. This would be in addition to fuel injector cleaner. I have had a check engine light that comes on at times. When I've had it checked, it comes back as a catalitic converter. I've had the catalitic checked, and it wasn't clogged.
Heres what it did today:
It was running fine all day, then I got gas. For some reason it would not stay running; I would start the car, and die almost immediately. Unfortunately I have to drive 30 miles for work, so I was able to get home. However every time I stopped, or had to slow way down the car would die. When driving I would feel the car "buck" a little, but I didn't have any problems getting home, as long as the car was running faster than 2000 RPM. I am fairly sure that the gas tank is under pressure when running, so I bought a new gas cap to see if that would fix the problem. It didn't help at all. In fact this is the first time I've ever heard it backfire.
So now I am trying to determine what the possible problem may be. I am thinking that it may be a dirty fuel filter, an O2 sensor, timing, or ignition.
If anyone has any suggestions, any help would be greatly appreciated!
Thanks in advance!
