Checking Rod Bearings... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2007, 12:23 AM   #1 (permalink)
Celica Enthusiast
bbmx952's Avatar
View bbmx952's Photo Gallery
Ok, so I have come to the conclusion that I most likely have a spun rod bearing, and Im pretty sure that its on cylinder #1. What I would like to do is jack up my car take the oil pan off and try and check and that it is for sure a rod bearing. I want to know, if I do this and the bearings look good then I should be able to put it back together and it should operate fine right? Of course this is assuming that I line up the oil holes and torque the bolts right.
Make: Toyota
Model: 1991 Celica GT
Engine: 5S-FE
Trany: 5 Speed Manual
Miles: 154k
bbmx952 is offline   Reply With Quote
Old 12-07-2007, 10:20 PM   #2 (permalink)
View toyomoho's Photo Gallery
If a spun bearing, oil has been cut off to the bearing and crank journal. The risk is the journal and connecting rod bearing surfaces have been damaged from lack of oil. You will need to inspect these, the bearing will need to be replaced.
Rod Bearings bbmx952 Celica Forum 6 12-05-2007 03:58 PM
Checking Rod Bearings SBS 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-14-2006 04:20 PM
98 camry 4cyl how to buy rod bearings dsparkaz Introduce Yourself Here 0 07-22-2006 07:13 PM
1zz-fe Warning!!! Rod Bearings and Lubrication 2001rolla Hardcore Tech and Competition 12 07-14-2006 02:19 PM
Rod Bearings and Window....>.< importdriver007 Camry & Solara Lounge 0 11-28-2005 09:40 PM
