3sfe Turbo Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2007, 03:48 PM   #1 (permalink)
View 88celica's Photo Gallery
3sfe Turbo Help!
ok so i have a 86 celica with a 3sfe swap (long story).... the 3s is completely redone ready for NOS or a turbo.... i personally want a turbo so i came across a ct26 completely redone by hks with zero shaft play and some off the wall intercooler pipes for $300.... so here comes the problem... where do i get a manifold? waste gate? and where in the hell do i put the i/c let alone which one should i use??? ive heard i could use a mkIII I/C because of the two outlets one the same side....
HELP!
88celica is offline   Reply With Quote
Old 12-10-2007, 05:36 PM   #2 (permalink)
6G Celi Specialist
Supersprynt's Avatar
View Supersprynt's Photo Gallery
HKS does not modify or rebuild Toyota turbos...
Anyway, the CT26 has an internal wastegate so you don't need an external one. You will need an actuator if it does not come with one. You can use a 3sgte manifold. I'm fairly certain it'll bolt right up, but I'm not 100%.
Supersprynt is offline   Reply With Quote
Old 12-10-2007, 06:04 PM   #3 (permalink)
ok how would i know if it had an actuator?? and where o where to find a stock manifold???
Old 12-11-2007, 08:47 AM   #4 (permalink)
6G Celi Specialist
The small circular thing on the bottom right of both turbos is the actuator.
Shop around the internet for a stock manifold: ebay, celicatech, alltrac.net...
Twin charged ECU? Blazin674 Archived Corolla threads 30 04-11-2006 08:25 PM
History of the Turbo... puzzle man General Discussion 4 01-24-2006 03:41 PM
Turbo installation for 3SFE, what I got so far almc2242 Hardcore Tech and Competition 6 02-01-2005 09:06 PM
Anyone wanna make a step by step 3sfe turbo install? spills1969 Camry & Solara Lounge 10 09-29-2003 01:02 PM
3sfe turbo high c Camry & Solara Lounge 8 06-24-2003 07:39 AM
