? about the rear in an 83 celica gt. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2007, 08:37 PM   #1 (permalink)
View 1lowGreenYota92's Photo Gallery
is it the same rear as a 89-94 Toyota pick up?
1lowGreenYota92 is offline   Reply With Quote
Old 12-13-2007, 07:52 AM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
First of all, find out what diff you have.
It will be a T (6.7") or F (7.5") series diff.
Look on the build plate in your engine bay and then compare it to this table.
http://members.iinet.net.au/~stepho/diff.htm
If you have an F series diff then you can get something from a 4WD shop (the F series was common on the 4WD pick-up).
- Stepho
stepho is offline   Reply With Quote
Old 12-13-2007, 03:34 PM   #3 (permalink)
Yah i have no cule im geting the car off my friend for $200 all i know about it is that its a 1983 Toyota Celica GTS and the rear is blown. and i was wondering if a 2wd pick up rear was the same cuz i have a spare from my hilux. Any help would be appreciated. Thank you in advance.
Old 12-15-2007, 05:15 PM   #4 (permalink)
RA28 + MX73
Okay, I've dug around through my micrifiche and have the following answer - maybe.
One of Toyota's great strength is that it can offer heaps of options to make your particular vehicle suit you.
But this makes it real hard to pin down exactly what is in each model because parts change so much between each variation.
The '83 Celica might have a T of F series diff according to the whether it was a manual or automatic, liftback or coupe, Canada or US.
Since you said you're looking at an '83 GTS, that means it is the RA65 (the one with Independent Rear Suspension).
Most of them had a F series diff, which was also common on the '84-'89 pickup.
But the auto coupe and auto convertible had T series diffs, which is not common on the pickup.
I looked up the microfiche for the pickup and it had 24 variations on the diff.
Some of them i recognised as F series diffs and some as G series diffs and many I didn't check into.
No real answer so far but there is still hope.
Take the pickup diff and measure the crown wheel (the biggest gear wheel).
The outside edge is at an angle, so make sure you take the WIDEST measurement.
7.5" means F series.
8.0" means G series.
While you're there, count the teeth for the crown wheel and also the pinion gear which meshes with it.
Then contact you're friend and ask him to tell you the contents of the build plate in the engine bay.
The 2 items I need are the model number (something like RA65L-BCMQEA and not JT2RA65...) and the transmission code (something like F293 or T302).
From these I can decode the diff type.
Or you can look it up yourself on my web page.
http://members.iinet.net.au/~stepho/celprod.htm#cel64pr
http://members.iinet.net.au/~stepho/celprod.htm#cel65pr
There is a good chance that they are both F series diffs.
If all else fails, then Toyota diffs are easy to find in wrecking yards.
Also be aware that if you change the diff ratio then your performance will change (better acceleration, less top speed or vice versa) and your speedo will be slightly wrong (causing speeding tickets).
Lastly, if the Celica has IRS and the pickup had a solid axle then you will have to pay a mechanic to disassemble them and reassemble the pickup gears in the Celica carrier.
The gears are compatible but the carriers are not.
Probably cheaper and easier to get another diff from a wrecking yard.
- Stepho
Old 09-14-2008, 12:25 PM   #5 (permalink)
View Erick561's Photo Gallery
Great Explanation but i think u lost the kid. Lol
1984 Toyota Celica GT
1979 Toyota Hilux 4wd 22r G54 4.88 gears 33"tsls
2003 Kawasaki KX250
1996 Ford Ranger V6 4.0 OHV 4x4 dd
Erick561 is offline   Reply With Quote
1980 Celica Camry GT HomeGrown 1st & 2nd Generation (1983–1986 & 1987-1991) 5 03-05-2007 08:40 PM
Will any parts off an 88 Celica GT fit an 88 Corolla wagon? Infinitrium Celica Forum 3 11-01-2006 09:53 PM
Would any parts off an 88 Celica GT fit my 88 Corolla wagon? Infinitrium Archived Corolla threads 2 10-27-2006 07:44 AM
89 Celica GT possible head gasket problem, new engine? djtmalta Celica Forum 1 10-05-2006 08:41 AM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
