Got it done yesterday, thanks...
just a not to those faced with this repair, carefully check over the replacement rad... Mine wasn't a Toyota part, and it took a "little" modification to work. I don't even call the dealer here in Canada, they aren't even trying to be reasonable. I had to change a PS hose last year, the one from the cooler line, with the big banjo fitting, up next to the cowl on the passenger side... Almost $300 here for a 12" hydraulic hose...
I found an aftermarket one on-line in the US for ~ $100, shipped.
Anyhoo, the captive nuts that hold the fan on wouldn't fit, they required a bit of grinding to fit the new rad. The clamps that hold the rad to the upper rad support didn't fit either. I had to massage them in a few places to fit.
The Toyota cap didn't fit either. It's ~ 41 mm and the new rad needed a 43mm cap, wich was fun to find at the parts store.
Anyways, thanks for the help!
Mike.
