2000 Celica Gt "evaporative system monitor" - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2007, 05:35 PM   #1 (permalink)
View SMILEITSDAISY's Photo Gallery
What is the evaporative system monitor? what parts do i need and where is there problem located. I already ran a diagnostic. p0171
SMILEITSDAISY is offline   Reply With Quote
Old 12-18-2007, 03:37 AM   #2 (permalink)
View 00mysticteal's Photo Gallery
Well the P0171 code System too lean (bank 1) you are most likely going to need to put O2 sensors on the car.
Your evap system, is what monitors your fuel pressures and vaccums to the car. It factors in a bunch of stuff from the intake and maf sensor to how much fuel and pressure is in the tank, it is a large amount of computer inputs and vaccum readings that help monitor all of this. Hope this helps some
00mysticteal is offline   Reply With Quote
Old 12-18-2007, 08:27 AM   #3 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
P0171 (System too lean, Bank 1) has nothing to do with the evaporative emissions. Evaporative emissions deal with how the car manages the fumes in the gas tank by storing and venting them into the engine where they are burned off. Codes that have to do with emissions start with a 4, like P0446 or P0440. Codes that have to do with engine control start with 1, like the one you have.
For one reason or another, the engine thinks it isn't getting enough fuel, and the mixture is lean. A common problem that causes this on celicas is the mass air flow sensor located in the intake boot just after the air filter. Other possibilities would be a vacuum leak, clogged injector(s), or a problem with the oxygen sensors, but these are usually few and far between compared to the MAF.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
2000 Celica gt unstopable24 Vehicles 3 11-07-2007 01:02 AM
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 11:30 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
2000 Celica GT Performance Parts ostentatious Celica Forum 4 08-10-2006 01:24 PM
Cruise Control system on '86 Celica GT coreolis420 Celica Forum 2 10-04-2004 12:56 AM
