Celica Brake Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2008, 07:41 PM   #1 (permalink)
View FrankieG's Photo Gallery
Hello,
I just changed the master cylinder and bled the lines. Now, I barely press the pedal and the car brakes. The worst part is the front driver side brakes locked up and were smoking. Has anyone encountered this problem before?
Thanks.
FrankieG is offline   Reply With Quote
Old 01-01-2008, 11:18 PM   #2 (permalink)
BANNED
View w203's Photo Gallery
caliper seizure, get it checked out
w203 is offline   Reply With Quote
Old 01-02-2008, 03:52 AM   #3 (permalink)
Thanks for the response
I'll get it checked out.
Old 01-02-2008, 05:26 AM   #4 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
When you changed the master cylinder you probably needed to adjust the rod connecting it to the pedal (or you accidentally adjusted it while swapping the MC).
- Stepho
stepho is offline   Reply With Quote
Old 01-02-2008, 05:59 AM   #5 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Yep, there is a specification for adjusting the brake pedal pushrod when you remove the master cylinder. Should be in your manual somewhere.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 05-04-2008, 02:39 PM   #6 (permalink)
View Silverceli19's Photo Gallery
hey, was wondering if you ever solved this problem? Did you adjust the pushrod or something else? I have been having this problem as of late and we've done quite a bit and no results. We changed MC, then the pads, rotors and calipers and still don't have much brake. Just wondering if you had any success.
Silverceli19 is offline   Reply With Quote
Old 01-05-2009, 10:13 PM   #7 (permalink)
View djleroue's Photo Gallery
Originally Posted by FrankieG View Post
Hello,
Thanks.
Don't really have an answer for you, but my '94 Celica is doing the same thing. Has been for quite a while. What I have to do is bleed the brakes all the time. It is weird, even if I let it sit and idle, the brakes lock up. My guess is the master cylinder is not releasing. I just ordered one and am going to be putting it in in a few days. I will get back to you and let you know if that does the trick.
djleroue is offline   Reply With Quote
Old 01-19-2009, 11:35 AM   #8 (permalink)
View PtypE's Photo Gallery
>.> sounds like a bad brake booster, that is only if you adjusted the rod connecting it to the pedal
PtypE is offline   Reply With Quote
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Brake and Tranny Problem fastwrx 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-01-2006 06:33 PM
Mysterious Brake Problem (2000 Camry) stangjason 3rd & 4th Generation (1992–1996 & 1997–2001) 7 07-27-2006 10:47 PM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
