4AFE head decked .011 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2008, 12:00 PM   #1 (permalink)
View Brianchevy's Photo Gallery
I'm in the process of rebuilding this 92 Celica with a 5speed and 4AFE. I dropped off the head for decking before the holidays and he just called to say it was ready. They told me it was necessary to take off 11 one thousandths (.011) in order to square it up. He said that was enough that it wouldn't seal a gasket and that he expected it to be OK going forward.
So, those of you who have needed a decking, is .011 normal? It seems sort of high, but I want to get your thoughts.
Brian
Atlanta
Brianchevy is offline   Reply With Quote
Old 01-02-2008, 10:30 PM   #2 (permalink)
after getting home tonight and going thru the chilton's manual, it appears that the specification is .002 which will not require any decking -- at least thats what chilton says, and he's pretty smart.
Anway, almost 6 times the limit, i guess .011 is ok.
I also found the reason for the car overheating and warping in the first case -- it appears that 1 set of fans is actually disconnected -- So, i'll have to work on that after we put this all back together...
brian
5efe head gasket still leaking, I need advice fast !!! reezytercel Tercel, Paseo, Starlet, and Sera Forum 9 05-23-2010 11:26 PM
happy 4afe top end wheredoesthisgo 7th Generation (1993-1997) 1 09-26-2007 12:22 AM
Large Port head on a 4afe block!!! jmaz87 Archived Corolla threads 1 09-25-2007 03:11 PM
How to remove the valve cover. 2slo5sfe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-09-2007 12:26 PM
