00 celica 1zz fe engine question"HELP" - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2008, 06:13 AM   #1 (permalink)
View TATERHEAD's Photo Gallery
on the oil pump on this engine 1ZZ FE 2000 CELICA, can the presure be changed by changing the the spring, was looking at some pictures and seen what apperred to be a presure valve monted on the front of the oil pump. the car is lossing oil presure after it heats up and rattles a little and the light flashes some and then stays on, also where car i get a engine manual for this engine, where is the best place for parts. or is the motor junk an need replacing, where would you get a long block. any help would be apprieated
tater
TATERHEAD is offline   Reply With Quote
Old 02-11-2008, 08:42 PM   #2 (permalink)
Electromagnetic Wave [:-h
2way's Avatar
View 2way's Photo Gallery
Try the fine folks over @ www.newcelica.org
But, I'd hazard to guess that you've either got a bad oil pump (not an uncommon failure) or you've got something else that's blown/bad.
'02 Celica GT-S/6 '96 Avalon XLS
'88 Camry DX Wagon '86 Camry DX Sedan '83 Corolla SR5 Liftback Wagon '82 Ford LTD-S(351W HO) '79 Corolla SR5 Sport Coupe '76 Corolla Wagon
PCIA Certified Mobile Communications Technician
2way is offline   Reply With Quote
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
Part Deux; 20R REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 21 09-06-2007 09:35 AM
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-05-2006 11:28 PM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
