Originally Posted by TubRog5
Looks to be in pretty good shape. Set your starting price at $1500 obo. What needs fixing?
What needs fixing?
Well the power steering pump is leaking fluid like it's a sieve. I have to add fluid to it at least once a month. The funny thing is that it doesn't leave puddles, but the alternator is just covered in PS fluid.
The rack and pinion needs replacing.
The engine needs a tear down and re-build (valve cover is seeping a little oil off the way around.) There is a lovely smell of oil mixed with a little bit of gasoline is noticed for the first 5 to 8 mins after the car is started each and every time, I have no idea what that's about...
The Valves need new seals (white puff of smoke once in a while at start up.)
There's an electrical gremlin that I haven't been able to pin down for over two years. I pulled off a kick panel on the drivers side under the dash and it seems to have gone away for now...
I think the suspension needs a good going over. There is tons of body roll right now.
Oh and if I crank the steering wheel too far while moving there is a very lovely crunch/clank/screech sound. I know it's most likely related to the rack and pinion but I'm not 100%.
All in all it's not major. The car just needs some money sunk into it. I REALLY want to tune it up and get some more HP our of it. But it's my daily driver and I can't be without a car.
