Squeeeeeaaaakkkk!!!!!!! Power steering prolem. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2008, 12:56 PM   #1 (permalink)
Blane's Avatar
View Blane's Photo Gallery
I'm frustrated. I've replaced the power steering pump with a new one. And it still squeaks when starting up the car in the cold. What causes that? Do I need to tighten the belt more untill it doesn't squeak no more.
I used prestone power steering fluid. Is that good to use?
Thanks guys!
Blane is offline   Reply With Quote
Old 01-21-2008, 08:23 PM   #2 (permalink)
View digmycelica's Photo Gallery
Thanks guys!
Sounds like the belt is loose if it only squeals when it's cold. check all the belts, the alternator is usually the one that squeals the most.
digmycelica is offline   Reply With Quote
Old 01-21-2008, 09:51 PM   #3 (permalink)
View toyomoho's Photo Gallery
Check the belt. Prestone is a god brand, the reservoir cap typically has the type of fluid to use.
Old 01-21-2008, 10:40 PM   #4 (permalink)
View liplip's Photo Gallery
There's no leak at all?
liplip is offline   Reply With Quote
Old 01-22-2008, 01:18 AM   #5 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
Did you "bleed" the system after replacing the PS pump?
On my 89GTS, you bleed it by going lock-to-lock a few times, not sure if it's the same for yours.
Rick89GTS is offline   Reply With Quote
Old 01-23-2008, 03:03 AM   #6 (permalink)
Blane's Avatar
I didn't bleed the system... I probably should.
How do I do that?
'93 Camry Power Steering Problem joeantispam 3rd & 4th Generation (1992–1996 & 1997–2001) 20 10-23-2011 08:34 PM
Just a little info I'd like to pass along.. Mr Marv Audio, Video, and Security - Tech 17 01-22-2008 08:49 PM
Problem with power steering... movement 1st & 2nd Generation (1983–1986 & 1987-1991) 3 11-16-2007 09:45 AM
Power steering nuron 1st & 2nd Generation (1983–1986 & 1987-1991) 4 04-18-2007 05:01 PM
Power Steering 86CRESSIDA86 General Discussion 8 01-31-2002 05:25 AM
