88 st idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2008, 10:06 PM   #1 (permalink)
View cactus88's Photo Gallery
88 st idle
88 st 3sfe auto idles smooth in reverse but dies when put in drive, I just installed a new fuel filter, air filter and spark plugs. I have adjusted the idle speed, at red lights I have to put it in neutral. any ideas?
cactus88 is offline   Reply With Quote
Old 01-23-2008, 03:04 AM   #2 (permalink)
Blane's Avatar
View Blane's Photo Gallery
Rough tranny....... Change automatic fluid to solve problem?
Blane is offline   Reply With Quote
Old 01-23-2008, 01:17 PM   #3 (permalink)
The transmission shifts smooth, the engine does vibrate and shake in drive. If you give it a little gas in neutral then put it in drive it will run, it seems to hesitate at low rpm. If I am parking the car and it is in neutral it will be running good, when I put it in park and the trans catches it will start to miss and sputter. What could cause this?
Idle drops/engine bogs in gear (auto) tsuave Celica Forum 2 04-17-2006 03:53 PM
99 4-cyl idle air valve removal sixto Camry & Solara Lounge 3 02-18-2006 02:16 PM
No idle 1980 Celica ST tray Celica Forum 1 02-06-2005 01:12 PM
