5SFE questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2008, 11:14 PM   #1 (permalink)
95 COROLLA's Avatar
View 95 COROLLA's Photo Gallery
Canada 5SFE questions
Ok i just bought a 1990 Celica GT-S mint shape but the engine needs a bit of TLC, anyways i was just wondering what kind of modifications you can do to a 5sfe to make it a bit faster iv been looking around but it seems all i can find is parts for the 3SGTE engine. and another question if you go to swap for a 3sgte do u use the transmission the engine comes with or do u use the 5sfe trans on the 3sgte? and one more thing i was replaceing the exhaust manifold gasket and whoever did it before broke a stud and used a bolt but it must have been striped because it came out too easy and wouldent get tight when i wanted to put the new one in, a buddy of mine said to try a healy coil? or re taping it and useing a bigger more course bolt. ok can anyone tell me which would be the better option? any help would just like make my day lol
thanks
Dan
95 COROLLA is offline   Reply With Quote
Old 01-30-2008, 04:46 PM   #2 (permalink)
Blane's Avatar
View Blane's Photo Gallery
I'm a heli-coil master. It's very simple to use. It uses a tap that's oversized and then an insert goes in and bam.... New thread!
You can buy kits at the local car parts store.
Good luck buddy.
Blane is offline   Reply With Quote
Old 01-31-2008, 10:51 PM   #3 (permalink)
95 COROLLA's Avatar
will a heli-coil be strong enough to hold an exhaust manifold in place tho?
Old 02-08-2008, 07:08 PM   #4 (permalink)
87 Supra N/A
View ToyCelGT's Photo Gallery
I have a 1992 GT with the 5SFE engine. I have a few plans for it. A few mods I will be adding to it are: Racing Header, Hi-Flow Cat., Performance exhaust, Venom Fuel Injectors, Venom Hi-Flo Fuel pump, Voltage stabilizer, light weight crank pulley, various cold air and short ram intakes, Venom 400 Control Module, SARD Speed Limiter Cut Controller, and a few other things. Personally I would just do a 3GSTE swap. You can get a lot more power out of it. With the All-Trac engine, most of them do come with the tranny, because its an AWD transmission, I dont think you could fit the Turbo engine to the FWD tranny.
ToyCelGT is offline   Reply With Quote
