Hi,
90 celica ST, 236K miles
Any comments on my NEW emissions results would be great. I have high HC (again) when engine is idle or low RPM, and this gets better with more load/higher RPM (see graphs below). I bought a new catalytic converter a year ago (for last inspection) and barely passed after that (it didn't change readings much). I believe my EGR is working fine, I've checked. My timing is, if anything, a little retarded. New Positive Crankcase Ventilation (PCV) valve. Plugs, wires, and cap will be replaced, but I had similar readings with all new ones last year. <-- same with air filter.
Should I replace O2 sensor? If I throw on a new cat it would probably help me pass again, but if I'm running lean or rich, I'd rather fix it and improve my mileage or performance.
Attached: I have scanned the readings graphs in case they can help you diagnose.
My readings (also on image):
HC - 2.0998 (1.4 GPM is limit)
CO - 13.0696 (30 is limit)
NOx - 2.5355 (2.5 is limit)
^Maryland limits
http://s301.photobucket.com/albums/n...=Emissions.jpg
Any comments will be appreciated and will help me waste less money!
Thanks
Additional Info - for some reason my cooling fan is always running. I changed the Coolant Temp Sensor and that didn't help. My car also has a hard start when its been sitting for a while (it's worse if cooler outside). --just in case it's relevant
