Help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2008, 12:11 AM   #1 (permalink)
View mrblonde108's Photo Gallery
Help!!
How do i get rear caliper mount off caliper?? 94 gt . There's no bolt head just a shiny cap with a rubber plug in the middle.
thank you
mrblonde108 is offline   Reply With Quote
Old 03-25-2008, 10:43 AM   #2 (permalink)
Blane's Avatar
View Blane's Photo Gallery
Remove all bolts that attach it to your suspension stuff. Then hit it with a huge rubber hammer. If it doesn't move that means you have another bolt.
Blane is offline   Reply With Quote
Old 03-25-2008, 10:47 AM   #3 (permalink)
caliper is already off. It has a swing mount attached to it i can't get off
Old 03-25-2008, 02:13 PM   #4 (permalink)
Gameroom cash: $147537
If caliper is rotating about the pin, rotate it up then pull. It just a sliding pin. Make sure you clean and use caliper grease before putting it back on.
Old 03-25-2008, 04:25 PM   #5 (permalink)
thanks for your answers. I'm a mechanic i know about the pins. The caliper has a pin going through it with a mount bracket. I don't know how the caliper is seperated from the bracket because there is no bolt head on the pin that connected them together. On this car to change the brake pads you remove one bolt then swing the mount bracket up. The pin that connects mount bracket to caliper is the one i can't figure out.
