need help wit a 83 st any body good wit these cars - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2008, 03:45 PM   #1 (permalink)
new to the TRD world
View merkedout83st's Photo Gallery
3rd Generation need help wit a 83 st any body good wit these cars
i have had this car for a year its been to tempe arizona and back all is but my tell lights and gage lights just went out break lights headlights and turning lights still work does anybody have any idea what it can be
and also what can i do to get a bit more hp 105 or whats left of it is not good ?
merkedout83st is offline   Reply With Quote
Old 03-24-2008, 03:42 AM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
Check the fuse for the instruments.
Might also be the ground wires for the instruments but that normally does weird things to the alternator light.
HP:
Bigger exhaust, bigger cam, Weber 32/36 carburettor (requires adapter plate).
Put a 20R head on the 22R block (raises the compression ratio).
Change the diff ratio to trade off top speed for acceleration.
- Stepho
stepho is offline   Reply With Quote
Old 03-29-2008, 10:57 PM   #3 (permalink)
View wilber's Photo Gallery
Take your 22R or 22RE block and put a 20R head on it,9.5:1 comp. pistons,any more compression and your lible to warp the aluminum head,headers,at least 2-1/2 inch exhaust,if your set up for fuel injection get 20% over stock injectors,any more than 20% and you have to change out your ecu for one that is calculated for the injector size,if your carbed 2 side draft carbs work best,you may have to adjust the Air Flow Meter,it is located between the air filter and the throttle body,cut the seal with a razor knife and lift off the lid,inside is a toothed adjustment wheel with a clip holding it in place with a screw,mark a referance point with a felt tip pin on the adjustment wheel,hold the wheel and loosen the set screw holding the wheel,turn the wheel counter-clockwise to richen the mixture,clockwise to lean it out,when done adjusting,seal the lid back on with silicon sealant-DONT LET DIRT OR WATER GET INSIDE AIR FLOW METER,IT DOES NOT LIKE IT!You may have to get a second elec. fuel pump to supply the needed fuel,run it in series with the factory in-tank pump.If your carbed,port the intake and exhaust ports.As for oversized cams,don't go over 280 duration,the engine doesn't like it,try a 256 duration-something that peaks at idle to 4500 rpm.Remember more cam is NOT always a good thing. Do this and your celica will scream,I've done it to my 84 celica and it leaves "high performance" Mustangs in the dust!
wilber is offline   Reply With Quote
