starting problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2008, 01:11 PM   #1 (permalink)
View wilber's Photo Gallery
starting problem
I have a 1984 celica that is hard to crank after the engine has been shut off for 20 minutes or more,it does this hot or cold.I changed the fuel injectors and pressure regulator but it still does it.Does anyone out there know what might be wrong?
wilber is offline   Reply With Quote
Old 03-27-2008, 01:20 PM   #2 (permalink)
Camry1999's Avatar
Gameroom cash: $211720
View Camry1999's Photo Gallery
Well...it could be your starter, but it might the timing belt, b/c if the timing's off, then that would give you that type of problem. On my dad's '91 Camry that I we just bought, it had a very similar problem when starting & when I used to accelerate , it would hesitate a few times before going. Later, I found out that the eingine timing was off a little, so we changed the timing belt & adjusted the timing & it runs great. See if that solves the problem.
'05 Camry LE-'08 'Rolla LE----my daily commuter-my sister's daily commuter
'97 Camry LE----my dad's daily commuter
'95 Camry LE Wagon----my mom's daily commuter
The rest of the fleet
TOYOTA PRIDE ALL THE WAY!!!!!
Camry1999 is offline   Reply With Quote
Old 03-28-2008, 07:00 AM   #3 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
Have you had the battery tested?
A failed battery will hold a full charge for a few minutes but will then fade away.
You can also test this by waiting 20 minutes and then starting with jumper cables.
If it starts easy then the problem is the battery.
Might also be the charging system but unlikely if it starts easy just after being turned off.
- Stepho
stepho is offline   Reply With Quote
Old 03-28-2008, 12:23 PM   #4 (permalink)
Starter Works Fine,problem Seems To Be No Gas In The Fuel Rail After It Sits,i Can Try Cranking It Immedeatly After Shut Off And It Cranks Fine,after 20 Minutes-hard To Crank,timing Chain And Gears In Good Shape,no Slack.
Old 03-28-2008, 02:24 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
22re right?
Old 03-28-2008, 02:57 PM   #6 (permalink)
Camry1999's Avatar
Well...we discovered that the problem was the timing. It was off by a little, now it starts perfect & runs a lot smoother & the stuttering problem's gone, now all that's left is the alignment & the CV boot...& it's perfect...minor stuff...
Old 03-28-2008, 07:56 PM   #7 (permalink)
Yes,22re.runs Great When It Cranks,just Hard To Start.
Old 03-29-2008, 10:55 AM   #8 (permalink)
View DavinaBG's Photo Gallery
I would have said fuel filter- easy cheap fix, often forgotten. glad your timing is fixed. : )
DavinaBG is offline   Reply With Quote
